Hyster J3.20xm
I have Hyster J 3.20XM
Serial : A 216A056512 Year 2002
Problem with the battery indicator It is not working good But I have new battery in it 80 volt
I make parameter 14 and 15 they are standing good.
I mounted extern battery indicator its working good Only the lifting is not work and on display coming battery low
Is there something that I can fix to let work the truck lifting and drive whit out the truck display !!!!!
Is there some one to give me the tip to fix this problem
Kindly regards
John.
  • Posted 4 Sep 2010 22:44
  • By johngen
  • NB, Netherlands
Hi John,
I'm not saying this to be a jerk but lift lockout is there for a reason (preventing battery damage). To bypass it would be doing a disservice to the owner of the truck. It would be better to fix it right. Does this truck have a GE pump controller or just a contactor?
  • Posted 5 Sep 2010 12:12
  • By certifiedtech
  • joined 5 Aug'10 - 39 messages
Hi John
I am not too sure but I had a problem a few years ago with a hyster which was causing lift lockout and display showing flat battery even though the battery and the settings in the control card were set correct.
I think we managed to change or disable lift lockout through the settings, but that was on the ev100 cards, however this truck I believe uses the Sep Ex GE controllers. However the actual problem was in the traction card.
After reading the following from the SEM controller section relating to lift lockout:
The lift interrupt feature will disable the lift pump controller when the connection at P10 loses the 12 volt signal from the traction controller.
This indicates that it may be that the problem may be related to the traction controller output.
  • Posted 5 Sep 2010 08:37
  • By elektrodrive
