Cat K series F/R levers breaking the roll pins
Does anyone know of a solution to the problem of over enthusiastic drivers breaking the roll pin which secures the F/R lever on these machines? Is there another stronger lever unit which can be fitted?
  • Posted 19 Aug 2010 19:07
  • By AndyPandy
Ed, generally i change the roll pins once or twice before the whole switch need replacing due to the wear you suggested. Training (which is the answer) these drivers is proving very difficult. I was just hoping that someone somewhere had found another stronger unit as a direct replacement. Because of the crank in the lever and the small roll pin these lever need careful use. A slightly different design could completely eliminate this problem.
  • Posted 20 Aug 2010 17:19
  • By AndyPandy
hello guys
why not experience the placement of springs. one solution is to use leverage with spring in the middle so that cushions the blow of the artists of driving. the other is to put springs and limiters. or use rubber blocks
  • Posted 20 Aug 2010 08:59
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
Training the operators is the -only- real answer, since there is no way that little roll pin can withstand an operators ham handed ramming of the switches lever.
I have also noticed that operators that were never trained not to jump out of the seat have a tendency to hit this lever with their knees as they egress the machine while facing away form the machine, which also causes/exacerbates this problem.
Maybe you can ask to speak to the operator it happened to to see what he was doing just before the failure, and show him the problem/ instruct him as to the proper method of changing directions.
Do you change the entire assembly or just the roll pin, since wear on the related parts may be a part of the problem?
  • Posted 20 Aug 2010 08:49
I do normally as well, but in this particular case the drivers are breaking so many, the customer wants something done about it. I have suggested driver training, but it fell on deaf ears.
  • Posted 20 Aug 2010 04:38
  • By AndyPandy
i have had this problem aswell but only with one or two customers. I just put down to driver damage.
  • Posted 20 Aug 2010 01:08
  • By Leon_W
  • Tyne & Wear, United Kingdom
