DEOOSAN DAEWOO B 1.8 T
Hi guys can anyone help me with a problem i have with a b 1.8 t the machine is driving very slow in fwd and rev.
I ramped up the speeds through the dash.
I have tried a different battery.
I have changed the main control card with another machine it was fine.
any help you can give would be a great help thanks.
  • Posted 19 Aug 2010 05:12
  • By Mag1
  • joined 24 Feb'06 - 25 messages
  • CO DUBLIN, Ireland
Hi John
Twin motors? If so lock out each motor and see if it makes any difference to the speeds. Check contactor tips for direction contactors and clean if required in case you are not getting a good connection through the tips.
Have you tried another foot pedal? Also is the bypass not energising? It may be the foot pedal is not reaching maximum output in order to energise the bypass contactor.
On some of the earlier model cats/daewoos the park brake switch could sometimes reduce the speed to the traction motors, even though I think on this truck it cuts out traction its always worth checking.
I am guessing no fault codes? If there was a component failure I would have expected some error codes or even if the thermal switch circuit was faulty it should also give some type of error indication.
If you dont have a spare foot controller to try this can be diagnosed through the diagnostic procedures.
  • Posted 19 Aug 2010 13:54
  • Modified 19 Aug 2010 14:00 by poster
  • By elektrodrive
