drive motor
The units drive motor is overheating and so is the pump motor they turn really slow no codes
  • Posted 3 Aug 2010 02:14
  • Modified 3 Aug 2010 02:14 by poster
  • By marc_a
  • joined 19 Feb'09 - 31 messages
  • Baja California, Mexico
A battery that is not charged sufficiently and sustaining a charge while under a load will cause intermittant issues without codes. Load test the battery for bad cells. Low voltage will reak havoc. So make sure the battery is good and fully charged before further diagnostics.
  • Posted 28 Aug 2010 23:11
  • Modified 28 Aug 2010 23:17 by poster
  • By JMMtheRoadDog
  • joined 28 Aug'10 - 1 message
the motors have speed sensors in the bearings and they need to be replaced. very common problem. the three "inmotion" controllers are interchangeable so if you want to verify the diagnosis you can rotate them and see if the problem follows the controllers. when you get done waisting time testing, pull the motors and replace the bearings
  • Posted 3 Aug 2010 09:38
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
Unicarriers FHGE35T5S
SMV (Konecranes) 4632CC5
RAEDER-VOGEL
