e104 for p20
hi
caAN I HAVE some help for fixing this problem the error is e104 is that when i plug in the battery connector the error is pop-up even the machine on its key-off mode....please help me to fix this...
thanx!
  • Posted 25 Jul 2010 19:53
  • By forkliftcity
  • joined 23 Jul'10 - 52 messages
  • cebu, Philippines
don't bite the hands that feed you!
I have a BT can key but the only parameter wich i can not change is the 22...It is flashing the 0 when i am trying...but nothing at all.
  • Posted 6 May 2011 01:04
  • By MikeGreece
  • joined 19 Nov'10 - 12 messages
  • sindo, Greece
Hi
You need to change parameter 22 from 0 to 1, to do this you need a BT can key OR Truck com.
Without a BT can key OR Truck com connected you aint gonna be able to change the parameter.
P20 machines from serial number 723984 onwards use the inductive type switch.
Until you change parameter 22 to the correct value of 1 for your inductive type brake switch then the truck is just gonna error out E104.
  • Posted 6 May 2011 00:08
  • Modified 6 May 2011 00:13 by poster
  • By Forkingabout
  • england, United Kingdom
Hello!
I have the same problem E104.
It is a model with the inductive sensor but the parametre No22 is 0.
I try to change it to 1 but I can't cause it is lock.
Does anyone have any idea how to fix this problem?
The power traction fuse and ptc resistor in K10 line contactor are OK and ofcourse the brake too.
Thank you!
  • Posted 5 May 2011 23:23
  • By MikeGreece
  • sindo, Greece
SHOULD BE TRACTION FUSE 125A
  • Posted 26 Mar 2011 11:21
  • By joel_zhou
  • joined 5 Mar'09 - 31 messages
  • singapore, Singapore
Hi,
first, check the power traction fuse and ptc resistor in K10 line contactor, this error tells about an error in the brake output.
Is important too to check parameter nÂș22 if the truck has a microswicht or inductive sensor in tiller arm.
Check the electro-brake, resistence must be 13-15 ohms.
Regards
  • Posted 30 Aug 2010 04:14
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
