heating problem
hi i have a over heating in three of my trucks, in the lifting sistem, do you know some tecnical coment about this or a modificacion about,thanks
  • Posted 29 Apr 2010 01:03
  • Modified 29 Apr 2010 01:13 by poster
  • By rodrigo_o
  • joined 5 Oct'08 - 12 messages
  • san salvador, El Salvador
are these units straight contactor operated or are they chopper equipped? if you're not sure post the serial #s. what exactly are you refering to as (overheated) what are the symptoms or codes. is the pump running constantly when battery is plugged in?
  • Posted 15 May 2010 10:38
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
How about changing to thinner oil?
  • Posted 14 May 2010 09:58
i did every thing that every body told me but my problem is there too and the over heating is blocking tthe sistem and tthe truck is not working ok. have any body forget something to do
thanks a lot
  • Posted 14 May 2010 01:43
  • By rodrigo_o
great advice Prentice. the only things i might add are battery condition / charge and check the cables under the battery.
  • Posted 5 May 2010 08:55
  • By toyzilla
Change the internal hydralic filter and check for colasped suction hyd lines.
  • Posted 4 May 2010 22:35
  • Modified 4 May 2010 22:39 by poster
  • By Prentice
is the motor ,that is overheating,all pressure is ok.
  • Posted 4 May 2010 00:59
  • By rodrigo_o
is it the pump motor or the oil that is overheating?
  • Posted 3 May 2010 13:22
  • By toyzilla
what is the pressure relief setting adjusted to?
  • Posted 30 Apr 2010 20:22
no don´t have attachements.
  • Posted 30 Apr 2010 07:50
  • By rodrigo_o
got attachments? got external pressure/flow control for those attachments?
  • Posted 29 Apr 2010 20:13
Michel Denis Michel Denis
