jugheinrich etm 14 error codes
I have an etm14 displaying error24 init4 and lowering stops when you move the joystick to max position, can anyone help,
pot and switch test ok
  • Posted 31 Mar 2010 21:20
  • By scott
  • joined 10 Dec'04 - 7 messages
  • auckland, New Zealand
Hi,
Error 24 means : EEProm cannot contacted /Parameter not plausible. Action : Check Battery voltage, Check if the truck type is correct, Set the parameters to default values (especially check the parameters concerning lowering function; if not work need to replace the control part.
Goog luck
  • Posted 3 Apr 2010 15:00
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
