7FBE18 DRIVE FAULT
LEFT SIDE DRIVE MOTOR LOCKING UP IN FWD & REV. I HAVE REMOVED MOTOR AND HAD CHECKED OUT AND IS OK. ANY THOUGHTS ? THIS IS A A/C DRIVE MOTOR SYSTEM.
THANKS
  • Posted 25 Mar 2010 11:09
  • By mrforklift
  • joined 10 Aug'09 - 39 messages
  • Queensland, Australia
Check with your Toyota dealer there have been a problem since 2003-aug2006.
  • Posted 25 Mar 2010 23:11
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
The simple things in Life are the greatest rewards!
Your looking in the wrong spot. Toyota had some issues with the final drive gear box bearing failing. Switch from gear oil to a transmission oil. Fluid should be replaced every P.M. Both sides. Take the wheel off, remove the bolts an the whole gear assy will come apart.
  • Posted 25 Mar 2010 22:42
  • By Prentice
