7FB15 no lift while in traction
have a problem with a 7FB15 (actually a 7FBL15-import) electric counter balance. Unit will not lift, sideshift or tilt with throttle actuated and direction selected. Also the units hour meter always reverts back to 0 as does the clock (after battery unplugged). Have replaced the memory battery under the lower control board in the dash which seems to have fixed the memory problem but the 'no lift while driving' problem is still there. I suspect the lower dash control board requires replacement but would like to hear other possibilties if anyone has one.
  • Posted 8 Mar 2010 17:12
  • By ryan_c
  • joined 8 Mar'10 - 10 messages
  • Queensland, Australia
hi sir toyzilla....i already fix the hour meter back to its normal operation but the material handling problem while in traction the same what inspection and troubleshooting i need to do? can u teach me how to fix this problem?
thanks in advance!
  • Posted 6 Nov 2010 11:01
  • By forkliftcity
  • joined 23 Jul'10 - 52 messages
  • cebu, Philippines
don't bite the hands that feed you!
either you need to start the hour meter (never got done) or the display battery has gone bad. if the hour meter has not been activated the unit can not be taken out of demo mode.
  • Posted 11 Oct 2010 05:42
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
hay edward did you already fix this problem? I'm working with the same model that you are talking. Although i already reset the demo mode and still the problem not fix. Also the hour meter still zero ad i think the truck is 3-4yrs old....
thank you in advance for a free information
  • Posted 11 Oct 2010 00:50
  • By forkliftcity
  • cebu, Philippines
Thankyou Edward, will do.
  • Posted 14 Mar 2010 12:05
  • By ryan_c
ryancdc at optusnet dot com dot au, but you can add it to your profile in the correct format.
  • Posted 14 Mar 2010 11:13
dont know if the email posted so i will break it up and then all to do is pull it back together
ryancdc
optusnet
.com
.au
  • Posted 14 Mar 2010 09:52
  • By ryan_c
Thanks mate. [email address removed]
  • Posted 14 Mar 2010 09:44
  • By ryan_c
email? just in case someone has the info
  • Posted 14 Mar 2010 01:32
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
Thankyou for the reply Rick. No i dont have the info. I have the button sequence to get into the computer but all is now in Japanese. Do you have this info?
  • Posted 11 Mar 2010 19:13
  • By ryan_c
your lift has reverted to its presale "demo" mode. you should be able to reprogram it. there is a very specific set of instructions for the after installation reboot. do you have that info?
  • Posted 11 Mar 2010 12:33
  • Modified 11 Mar 2010 12:40 by poster
  • By rick_c
ROYPOW
