Crown RD3000
Need to know if the steering on these units can be reversed. Serial number is 1A185346. Any help would be great. Thanks.
  • Posted 27 Feb 2010 04:06
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
That only works on a 5000 series and above. Older than that you must add a sprocket and chain as described above as the torque generator attaches directly to the manifold block.
  • Posted 4 Mar 2010 05:20
  • By roadtek
  • joined 4 Dec'07 - 123 messages
Quick and easy way is just to change the hydraulic hoses from port A to port B and vice versa at the steering valve.
  • Posted 2 Mar 2010 13:22
  • By richard_y
  • joined 9 Feb'07 - 66 messages
  • Singapore, Singapore
you have to know if you have forward or reverse, rite now. just have to add or delete a sprocket and chain.it is wound all the way around for rev. forw. needs sprocket, wound to the inner of new sprocket. :)
  • Posted 27 Feb 2010 16:51
  • By trina_m
  • joined 27 Feb'10 - 2 messages
  • Alberta, Canada
hi, garland. i sent you some info that can help.
adolfo.g
  • Posted 27 Feb 2010 12:17
  • By roldann
  • joined 3 Sep'08 - 86 messages
  • nuevo leon, Mexico
Bolzoni SpA (Group HQ)
