CNG driven Forklifts
Just wanted to know who manufacturers
CNG Forklifts in USA? And what range in Price approximately
All feed back appreciated
Thank you
  • Posted 4 Mar 2006 06:31
  • By jayjay
  • joined 4 Mar'06 - 1 message
eport
contact Toyto industry
  • Posted 13 Apr 2011 22:29
  • By vishal_s
  • joined 13 Apr'11 - 2 messages
http://www.gofleet.ca
What a gas!
  • Posted 2 Feb 2011 11:08
  • By misterfixer
  • joined 2 Feb'11 - 1 message
  • Indiana, United States
canadian company has retro fit carb or injection system for any forklift ferris fuels located in ontario canada has been fitting my forklifts with systems for 8 years now hales crowns hysters toyotas and a cat i have had done
  • Posted 2 Feb 2011 02:16
  • By brutus
As previously stated, only Toyota is offering an EPA /CARB certified CNG forklift for the US market. Present government regulations make it very unattractive for any OEM to enter the market as each certification is engine year and model specific. We presently supply certified LPG and gasoline fuel injection systems for GM engines and are the MOR for Mazda 2.0L, 2.2L and GM 2.4L and 4.3L engines, and to date not enough interest to make it worthwhile certifying a CNG variant for any of our customers.
  • Posted 30 Oct 2010 06:13
  • By peter_r
  • joined 30 Oct'10 - 1 message
Thsi goes back a little bit (8 years ago) but there is/was a company in Ohio that mad a CNG kit for forklift - the engine had to be an OEM LPG fuel engine. The Coversion kit was about $2600 & that is a SWAG. With all the Tier 1,2,3,4, etc maybe the systems can't be retrofitted due to CARB regulation. Do a Google search & maybe you can locate them & get more accurate info.
In my opinion CNG is overated for forklift operations. My rationale. A fuels energy rating is based on BTU (British Thermal Units). For example if we assign a BTU value of 100 to gasoline; then LPG would have a BTU value of 85% (less power out of the engine - less torque to the wheels). Well with CNG the assigned value would be about 70 (20% less than LPG ) & the unit performance is further reduced (some say not enough power to pull a sick person out of bed - had to clean it up a bit to maintain political correctness. There is less run time per tank full even though the tank is lmuch larger - more refilling required - If you need fast refills the refill station is a bit expensive. If one requires 5 trucks running on LPG to do the work, then you would need to increase the fleet size by 20% or one more unit to do the same work but also more emissions -hmmmmm. If one is a union shop or government run opertion that might be OK.
Other than that CNG is good.
  • Posted 28 Oct 2010 06:33
  • By johnr_j
  • joined 3 Jun'06 - 1,452 messages
"Have An Exceptional Day!"
This is Jim with HE System Technologies.We are the USA division of TEU Forklifts. We offer a line of clean burning high power true CNG forklifts. We also carry CNG compressors and accessories for your fueling. CNG is smart fuel. LPG ranges @3.50 GAL, CNG can be as cheap as.65. Give me a call @773-747-8440. We can discuss your needs and specifications.
Thanks
  • Posted 27 Oct 2010 15:08
  • By jim1882
  • joined 27 Oct'10 - 1 message
  • Illinois, United States
True CNG Forklifts
Hanck,
Please contact:
TOYOTA INDUSTRIES MERCOSUR LTDA., Argentina branch
RUTA PANAMERICANA, KM. 28.5 DON TORCUATO B1611 GFX BUENOS AIRES, ARGENTINA
Tel: 54-11-4846-1892
Fax: 54-11-4846-1896
http://www dot toyota-industries dot com dot ar
They can give you more info on actual specififcations
of a UL approved CNG truck!
  • Posted 20 Jun 2006 10:56
  • By trainer
  • joined 21 Jan'05 - 35 messages
Hanck,
Please contact:
  • By trainer
Argentina is the world´s biggest user of CNG for cars. Obviously that has led any amount of gasoline engined forklift truck users to convert to CNG/gasoline. Any gasoline engine can be converted at low cost, but CNG burns hotter and many engines, specially the ones with aluminium block and heads end up with burned out valves and valve sleeves sinking any where up to 3 mm into the aluminium block. That whipes out any possible savings or low poilution advantage.
  • Posted 20 Jun 2006 02:02
  • By hanck_c
  • joined 30 Dec'04 - 14 messages
  • Capital Federal, Argentina
Jayjay I see you export...
contact:
ToyotaLift of Houston
(Carruth-Dogget, Inc.)
7110 North Freeway
Houston, TX 77076
Phone: (713) 675-7000 / Fax :(713) 675-7939
Sales Contact:
keith.mckinstry(at)tlotx (dot)com
  • Posted 9 Mar 2006 15:23
  • By trainer
I'm your Huckleberry!
To my knowledge Toyota is the only MFG to make one on the line
this inclues Class IV
call your local dealer for current pricing will not be much diff from lpg price
many advantages..
also UL and Carb approved!!
  • Posted 9 Mar 2006 15:20
  • By trainer
Todd J Doxsee Todd J Doxsee
Sales operations, Heli
Chief financial officer, Cyngn
Executive vice president and chief commercial officer, East Penn Manufacturing
