code c-28
Have this code C-28 and cannot get things to work at all sometimes, and sometimes travels slow. machine will work ok at times anyone have answers for this condition
  • Posted 9 Dec 2009 09:26
  • By neforklift
  • joined 21 Dec'07 - 4 messages
Common problem, coupled with the slow travel I suspect bad main harness. Pull off the tiller/handle, check for the harness rubbing on the frame, and shorting out very very common issue. Might need to fully replace the harness if bad enough.
  • Posted 17 Nov 2011 14:15
  • By grego
  • joined 15 Nov'11 - 12 messages
  • Alberta, Canada
Check emergency switch first,
A bad lift selinoid will cause this. K10 Relay f'd.
  • Posted 2 Oct 2011 16:53
  • By DarrenG
  • joined 2 Oct'11 - 1 message
  • Saskatchewan, Canada
k10 contactor is in closed position. its welded sometimes and also check the ptc resistor if its hot sometimes it is due to the contactors closed before you switch on the truck.
  • Posted 29 Jul 2010 01:51
  • By forkliftcity
  • joined 23 Jul'10 - 52 messages
  • cebu, Philippines
don't bite the hands that feed you!
i would start with the battery
check each battery individually and check the cables between them
  • Posted 16 Jan 2010 08:21
  • By RookieTech
  • joined 22 Oct'07 - 4 messages
I would check the emergency switch near where the battery plugs in.
  • Posted 15 Jan 2010 10:49
  • By MtnMan
  • joined 9 Jun'07 - 8 messages
  • Alabama, United States
Komatsu FD25T17
Maxlion FDR45
