field calculation to determine load capacity
I am looking for a field calculation/test example to determine the load capacity of forklift truck. Also, I would like to know how to reduce the load capacity due to side-shifter instalation, and/or due to facing a non standard mast (higher). Asme/As std's suggest about 4 tests for this purpose but I could not calculate more than 2 of them ( i do not have the c.g info belong to the above new configurations- i.e. unladen FLT mast up).
  • Posted 9 Nov 2009 01:30
  • By gl_l
  • joined 9 Nov'09 - 18 messages
  • israel, Israel
Lets be realistic.
Theoretical calculations are one thing.
" out in the field " as you say is another.
There you must allow for stupid operators, Bad loads , uncertain ground conditions Etc Etc
Anybody who does not allow 25% for those little extra's can expect trouble.
  • Posted 26 Nov 2009 23:36
  • By Normandy
  • joined 28 Sep'06 - 186 messages
  • Co. Cork, Ireland
Lets be realistic.
  • Posted 26 Nov 2009 23:34
  • By Normandy
  • Co. Cork, Ireland
Hi all, came across cascade web site as a recommendation from one of the other discussions it has a capacity calculator on it ,you just put in information and measurements and it does it all for you.hope this helps.
  • Posted 26 Nov 2009 05:30
  • By daryl_j
  • joined 12 Sep'09 - 46 messages
  • manchester, United Kingdom
I agree with Dan. Any attachment you place on your lift truck, whether it is a carton clamp, roll grab, or a side shifter should have a capacity plate attached to your lift truck stating the specifics, which is available from the manufacturer.
  • Posted 10 Nov 2009 23:59
  • By TC17
  • joined 17 Apr'08 - 53 messages
  • Wisconsin, United States
Wisconsin, USA
"Be safe"
I dunno. I would leave that figuring out to the OEMs!
  • Posted 9 Nov 2009 12:34
  • By dan_m
  • joined 14 Oct'05 - 337 messages
Taylor TT300
USD98,500
Airman ENCL045
Taylor TT300
USD98,500
Airman ENCL045
Taylor TT300
USD98,500
Airman ENCL045
