towmotor oil plug location
I just purchased an older towmotor forklift which is a four cylinder LP. i can't seem to locate the oil plug, is it easy to get to?
  • Posted 13 Sep 2009 11:34
  • By Alex92
  • joined 13 Sep'09 - 2 messages
  • Michigan, United States
1. If you just want to see where it is - get a mirror and slide it under the forklfit in about the same area as the rear end of the engine.
2. If you want to drain oil easily - it is best done with the forklift jacked up and securley supported on hard wood blocks - consult with your local dealer on the proper way to do this.
  • Posted 14 Sep 2009 12:02
  • By johnr_j
"Have An Exceptional Day!"
The model is a 422SG3024
Serial Number- 422S660329
I Know that the plug is on the oil pan but is there an easy way to get to it? There isn't enough room for me to see exactly where it is.
  • Posted 14 Sep 2009 01:24
  • By Alex92
Yep, It's on the bottom of the oil pan.
OK, Thats enough sarcasim. Can you give us the Make, Model & Serial number of the truck??
Little things like this help us help you when you have a question.
You wouldn't walk into a car parts store and say"I need a filter" would you without getting the deer in the headlight look.
There is a wealth of information, tips & hints to share here, there are a LOT of experienced techs that read this site and are willing to help.
  • Posted 13 Sep 2009 13:53
  • By roadtech
UN Forklift FB20-35FZNLZD
Nagano NUL120-6
