Nissan hard starting
I have a Nissan EGH02A-30V with a SD25 diesel engine. It starts extremely hard, however once it has been started it starts fine thereafter unless it sits for some time. We thought that the fuel was bleeding back to the tank and installed an inline check valve and still the same problem. I have contacted some Nissan dealers and they told me that it is an inherrent problem with the engine. Any suggestions would be appreciated.
  • Posted 19 Jan 2006 00:47
  • By duodeluxe
  • United States
duodeluxe
I ALSO HAD THIS PROBLEM WITH THE SD 25 ENGINE
I CURED IT BY TURNING THE INJECTION PUMP BACK TOWARDS THE ENGINE BY 2 DEGREES THIS ADJUSTS THE TIMING SLIGHTLY SO BE CAREFUL YOU DONT GO TO FSR OR YOU MIGHT GET ENGINE DIESEL KNOCK
  • Posted 24 Feb 2006 08:39
  • By Mag1
  • joined 24 Feb'06 - 25 messages
  • CO DUBLIN, Ireland
