Will Not Start
H20T-03 S/N H2X350S04154
When the ignition key is turned to the on position there is not any voltage to the fuel lockoff, even when you are cranking no voltage is ever present. The electronic accelarator module does not move either. Any ideas of which dirrection i should go? If i disconnect the lockoff and use jumper wires to it the engine will start, but the direcetion controls will not work or it will not accelarate.
  • Posted 26 Jun 2009 00:44
  • By VXman
  • joined 14 May'09 - 34 messages
  • Oklahoma, United States
Check key switch
  • Posted 22 May 2015 11:43
  • By edward_m
  • joined 11 May'15 - 111 messages
Hi VXman
The truck you have is a digital truck so everything is controlled via the module,when you switch on the module checks everything then if all is ok gives the signal to the gas lock off valve and the electronic speed control magnet,also the signal is given to the drive release solenoid,by connecting the gas lockoff you are bypassing the module but it still won't drive or rev up.
Ideally you need a laptop with pathfinder/truck doctor to see what fault codes are showing,without lap top try looking at the fuses under the display there should be a 1 amp fuse this protects the module and is has blown try another and a 15amp fuse that suppy12v to the module.Check the speed sensor on the fly wheel ths also communicates with the module.
If you have another truck on site try the module on that truck to confirm it has not gone down.
There is not lot else you can check without laptop,
Good luck if you need any more info just ask,
cheers
herald
  • Posted 26 Jun 2009 04:14
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
Taylor TX330S
USD159,500
SMV (Konecranes) 20-1200B
Yale Lift Truck Technologies
