yale GLC040VX with mazda engine/ how hard is water-pump R/R?
My customer has a yale GLC040 with a belt driven SOHC mazda engine (F2 Z25D 2.2l). the water pump is noisy, and the shaft can be seen shaking when thw engine is run with the timing covers removed. What is involved in replacing this pump? Is it a practicle job to do on the road, and are any special tools needed? Thanks.
  • Posted 16 Jun 2009 02:27
  • By fixitandy
  • joined 23 Mar'09 - 81 messages
Allow yourself the effectiveness of the water pumps from crazysales using this 350W Automatic Water Pump! Worthy of household gardens or farming, this impressive multi-stage pressure pump can be your reliable working partner. Having a abundance of great, powerful specifications featuring, it was made to supply a continuing and stable pressure solution.
  • Posted 13 Apr 2017 12:36
  • By jack_l
  • joined 13 Apr'17 - 1 message
  • New South Wales, Australia
https://www.crazysales.com.au/water-pumps/
I also recommend changing the timing belt, cam and crank seals while you have the front of the motor open. It will save your customer some down time and additional excess labor down the road.
  • Posted 16 Jun 2009 04:25
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
It is a fairly easy job to do on the road and there are no special tools needed.
  • Posted 16 Jun 2009 03:58
  • By danny_k
