LPG Carb
We currently have a duel fuel system on the forklift and the gas carb needs replacing.
We are interested in changing it over to just LPG, can anyone suggest where i can locate the correct carb and accessories needed. I did call one parts place locally but have not heard back from them.
  • Posted 1 Jun 2009 23:15
  • By albert_h
  • joined 22 Aug'06 - 59 messages
You can call MHS ( Material Handling Supply) at 562-921-7715. They are a Mitsi / Nissan dealer in Santa Fe Springs.
They can set you up with a aftermarket carb kit and all the other needed parts. When you call make sure you have the trucks Make, model & serial number, it helps them a lot. Whan you set the motor up for straight LP make sure to replace the spark plugs and gap them to.28-.32, I'd just do a major tune up since you'll be so deep into it anyway.
  • Posted 4 Jun 2009 12:40
  • By roadtech
