PowerShift
Please let me know differences between transmission type: PowerShift, Manual and Automatic.
Thank you very much.
Best regards.
  • Posted 2 May 2009 18:28
  • By matrix_thanh
  • joined 13 Sep'08 - 7 messages
  • gfdgf, South Africa
wandler is german for tranducer
  • Posted 6 May 2009 23:18
  • By KMB_lift
  • joined 25 Mar'09 - 5 messages
  • Connecticut, United States
Thank you very much for your answer. It is useful for me.
I also ask the Transmission Type: Wandler.
Please help me.
Best regards
  • Posted 6 May 2009 13:23
  • Modified 6 May 2009 13:24 by poster
  • By matrix_thanh
Sure glad he didn't ask about the Hydrostatic transmission - I would refer him to his local Linde man.
Lift truck transmissions course 101
Manual transmission - is a mechanical transmission using gears as primary method to transfer power from teh engine to the driving axle. It requires a clutch disc & pressure plate and is operated usually by the left foot with pedal in the operators compartment. When teh pedal is depressed the operator can select forward or reverse travel & various speed ranges.
Power Shift transmission - a transmission that utilizes a torgue converter & hydraulically applied clutches that allows the transmission to change directions with a lever that activates a hydraulic valve on the transimission. Typically, most Power Shift transmission are single speed.
Automatic transmissions - are similar to Power shift transmissions except they can have 2, 3 or 4 different speed ranges. A true automatic transmission will shift from low range to the high ranges "automatically" similar to an automobile. In lift truck operations sometimes a lock out of the automatic shifting is provided when high driving power is required for an extended period - like getting stuck or carrying a heavy valuable load, etc.
  • Posted 4 May 2009 01:33
  • By johnr_j
"Have An Exceptional Day!"
