Travel fault
Can anyone tell me what would cause this travel fault. When attemptimg reverse the unit bucks and goes in to neutral. When you let off the accelerator it will return to reverse and you do it all over again. Unit will not fault out. If you attempt to travel slowly in reverse and get it rolling it works fine. You can get full speed. Also the regen braking for rorward works until around 3 mph and kicks out to a full coast. When you can get reverse to work, the regen works fine there.
  • Posted 1 May 2009 02:46
  • By TimM
  • joined 26 Nov'08 - 7 messages
Thanks! Tim
R60-40 is a Still. You have to enable the service adress to read the fault on the display. RX60-40 could be a Linde or a Still but it's the new generation.
  • Posted 14 Nov 2009 15:27
  • By Dwaive
  • joined 7 Aug'09 - 33 messages
  • Quebec, Canada
Is the truck you are working on a Still or Linde?
Don't recognise the model,what s the serial number?
  • Posted 6 May 2009 00:44
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
im not sure on this machine
but
from experience
lindes (and still which i believe this actually is)
you have to enable faults to display or you have to read them with a laptop
  • Posted 2 May 2009 12:39
  • By justinm
TCM FHD105Z
Maxlion ESD15M
TCM FHD105Z
Maxlion ESD15M
