code 215 after drive unit replaced
I replaced a drive/motor assembly with an assy. from another unit. Now when I go thru startup I get a wrench and a code 215 (No turn to left) The drive steers about 10 degrees to right. Normally the drive moves right to left then back to index. I readjusted to encoder 2 to index. Swapped out the steer control module, replaced the K5 relay and even put in a good encoder. No help. With the encoder unplugged the drive vibrates right to left as normal but then codes a 208. Is there anything that can cause this just by replacing the drive motor and lower unit?? Even swapped out relays on distribution card. Anyhelp will be greatly appreciated. Thanks Ed Bowen 443-463-0555
  • Posted 16 Apr 2009 07:41
  • By bunky
  • joined 16 Apr'09 - 4 messages
  • Maryland, United States
i have a sp 3020-30 giving code208 in the book is gives a(i change the steering feedback encoder same problem) troubleshoot sequence , at the point it says hook up a volt meater and check for voltage from steering modula POS. TB407-2 AND NEG TB407-3 , i and getting 1-.7 volts any one knows what the problem is ,
  • Posted 1 Dec 2011 12:57
  • By phillboy
  • joined 5 Mar'11 - 7 messages
  • New Jersey, United States
trap for young players, sorry lol.... I get a lot of calls about this
  • Posted 15 May 2009 20:45
  • By julesrobdog
  • joined 13 May'09 - 11 messages
Found the problem. The front wheel must be on the ground and bare weight in order for the test to run complete.
  • Posted 17 Apr 2009 09:38
  • By bunky
SMV (Konecranes) 33-1200C
Maxlion R2D35
F. Uchiyama
F. Uchiyama
