TOYOTA IMPCO SYSTEM
I`ve got a 6fg25 that starts well but do not rev up unless the choke button is pressed.I swopped the regulator,filterlock and mixer from another 6fg25 that had no problems but the problem is still there, any ideas?
  • Posted 4 Jan 2009 04:52
  • By fik_c
  • joined 4 Jan'09 - 6 messages
  • WESTERN CAPE, South Africa
Well done fik c it is always good to get feed back rather than like some guys who just keep quiet once they have got the information and fixed the problem.......... I have come across blocked manifolds on the Toyota 4Y engine a lot, seems to be when the engine starts to get a little bit worn and starts to breath through the PCV valve, the gunge then builds up on the hot spot between the exhaust and inlet manifold...........I have seen them so you can hardly get a screwdriver through the hole!
  • Posted 8 Jan 2009 06:19
  • Modified 8 Jan 2009 06:20 by poster
  • By DaveUK
  • joined 12 May'06 - 44 messages
  • BERKSHIRE, United Kingdom
Who bravely dares must sometimes risk a fall.
Thanks for all the help. Manifold was the problem. Not dumb Prentice, plastic wrap is causing us a lot of problems, like broken fanblades damaging radiators.
  • Posted 6 Jan 2009 03:27
  • By fik_c
Do not take this the wrong way but i have seen this happing allot. Check the air intake on the back right or left overhead guard. Make sure that the driver has not put plastic wrap on top to stop the rain and blocked off the air intake. It sounds dumb but i have seen it stall out an engine
  • Posted 6 Jan 2009 01:23
  • By Prentice
Looks as if you have tried just about everything, has the 6 series got a 4Y engine? if so I agree with snapman, it could be a blocked manifold, but you would have seen this if you had the governor off!
  • Posted 5 Jan 2009 07:49
  • Modified 5 Jan 2009 07:50 by poster
  • By BobbyT
  • joined 25 Dec'08 - 31 messages
  • Wilts, United Kingdom
Thanks.I replaced the fuel hose and checked + adjusted the governor.Will check the manifold.
  • Posted 4 Jan 2009 18:28
  • By fik_c
I've seen the fuel hose from the regulator to the carburetor collape or crack and cause a no rev up problem on Toyotas.
  • Posted 4 Jan 2009 13:13
did you check the or replace the governor too?
  • Posted 4 Jan 2009 11:49
  • By justinm
Is the inlet manifold bloked up as this will give you that fault.
  • Posted 4 Jan 2009 09:13
  • By Snapman
  • joined 10 Sep'08 - 53 messages
  • Liecester, United Kingdom
Briefs United States
