The engine does not rev when cold
Hello!
Can anyone help me with the problem that the engine does not rev when it is cold for the first time and does not warm up for 5-10 minutes. It does not display any error codes.
Thank you in advance for your help.
  • Posted 5 May 2025 18:22
  • By Sifi
  • joined 21 Sep'22 - 3 messages
  • Hungary
Thanks, I will check these out.
  • Posted 5 May 2025 20:12
  • By Sifi
  • Hungary
if the unit is on lpg more than likely you have bad gas convertor and you also need to check that you dont have a water blockage also check thermostat that its working correctly and also check water pump is operating correctly
maybe that someone has removed the thermostat for some reason see how you go with that
  • Posted 5 May 2025 20:06
  • By skyreach
  • joined 2 Apr'22 - 40 messages
  • Victoria, Australia
reach for the sky
VETTER Forks, Inc.
