Hobart Chargers
Hi - anyone have any experience with these, or know how to contact the manufacturer?
  • Posted 12 Feb 2025 09:06
  • By Battman
  • joined 12 Feb'25 - 3 messages
  • Alberta, Canada
Have a good day!
Hi. I'm an EE specializing in Lithium batteries. I know not all Lead-Acid chargers are compatable with all Lithium batteries, and it matters. In this case the voltage for FLA matches up pretty closely with the Lithiums, and equalization is not necessary, nor will it work (the batts will detect a higher voltage and shut off). It will charge them more slowly than an equivalent Lead-Acid in the last 20% of the charge, but that's okay - they just need an overnight charge.
It's quite possible there's something wrong with this charger however, and I'm not familiar with it - slightly intimidated, actually - so I thought I'd see what some common issues are, so I know where to look. Thanks.
  • Posted 18 Feb 2025 04:34
  • By Battman
  • Alberta, Canada
Have a good day!
Battman,
LI batteries charge at a different rate than lead acid. You should talk to the charger and battery reps to make sure they are compatible. Good Luck.
  • Posted 18 Feb 2025 03:56
  • By Fishmech
  • Virginia, United States
Hi. Thanks. We are putting a Lithium battery into a pallet jack. I'm mot sure if the charger was working previously, so will keep you posted.
  • Posted 18 Feb 2025 03:50
  • By Battman
  • Alberta, Canada
Have a good day!
Battman,
Go to hobartparts.com/manuals, they list multiple manuals and contact info that should help. Make sure to check all fuses, including any around the control board. Do not put a higher amperage fuse in as this could possibly damage the charger. Good Luck.
  • Posted 17 Feb 2025 23:05
  • By Fishmech
Danville, IL, United States
Toyota 3FD100
Hangcha CPYD35XH21F
Flesherton, Ontario, Canada
Andries Retief Andries Retief
Chief development officer, DHL
Director, ICHCA Australia
CEO, TVH
Sales and operations director, Logitrans A/S
Hyster
CEO, TVH
