transmission
hi, having a problem here with this forklift, it kicks out of gear while driving in any speed 1 through 3, even reverse. now checked fuses, relays i have checked some it has blown out while driving so can anyone help solve this issue. thanks
  • Posted 6 Dec 2024 23:33
  • By DrJoe67
  • joined 6 Dec'24 - 2 messages
Dr Joe
Thanks Fishmech, the Hyster is a column shift H210HD ser# H007E02187F, right now our supervisor has me pulling the Control Valve which I don't think is the cause but I will follow what you wrote once I have it back together. Thanks for helping.
  • Posted 10 Dec 2024 21:58
  • By DrJoe67
Dr Joe
Joe,
What controls the trans shifting, throttle pedal or shift lever on column? If shift lever on steer column, hold shift lever with a little pressure like you are trying to engage and see if it will stay in gear. Make sure to test in reverse and forward. If it stays in gear, shifter is worn. Also, take off the steer column covers and check all wiring for any wear or damage. Three different models of truck, serial number would help.
  • Posted 10 Dec 2024 00:17
  • By Fishmech
  • Virginia, United States
Sue Tomic Sue Tomic
F. Uchiyama
Sue Tomic Sue Tomic
F. Uchiyama
