Error 2:555
Hi guys,
Can somebody helps me, When switch on the truck an hourglass appear on display and takes too much time then shows error 2:555. I have checked the fuse F7 which is fine but have no clue where the problem is.
  • Posted 6 Dec 2024 03:21
  • By Syed
  • joined 14 May'15 - 195 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
Dear ximm_hh,
The main contactor engages and then release after error 2:555. I found 48 V on F73, ACT and ACH but still confused why and where this fault is coming from. The truck model is RRE200E / 6115971.
Ill check the battery and then let you know.
  • Posted 24 Dec 2024 18:55
  • By Syed
  • Sindh, Pakistan
hello syed
is it possible to provide me with a picture of the ID label? This way i can check the diagrams for your particular truck. I fear the Main board computer does not receive a valid input.
Meanwhile, does the main relay engages?
Also if u have the possibility to change the battery as a test, please do so. Bad batteries tend to trigger alarms in alot of cases.
  • Posted 9 Dec 2024 06:42
  • By ximm_hh
  • joined 9 Dec'24 - 1 message
  • Netherlands
The error has not been resolved yet. can somebody help me?
  • Posted 8 Dec 2024 07:44
  • By Syed
  • Sindh, Pakistan
