Idle power off setting.
I have a handful of Crown reach trucks here (All ranging from model RR5725-45 to model RM6025-45) and am curious if there is a way in order to set them to shut off automatically after an idle time has been reached.
I have navigated into the service menu and am unable to find anything that might suit my requirement.
If it isn't possible in the settings, does anyone have a recommendation for a -relatively cheap- third party module I could install.
Thanks in advance!
- Luke C.
  • Posted 30 Nov 2024 04:02
  • By Br455Brute
  • joined 30 Nov'24 - 9 messages
  • Alberta, Canada
No problem! Crown does also offer a keypad option as well for pallet trucks if you wish to add a login to those.
Infolink is an amazing product but it can be pricey as it costs about $1000 per module and then you have to pay a month fee per truck. Depending on your fleet size it might be a great fit! Helps log collisions, operator training, PM schedules, inspection checklists, automatic time outs, and so much more
  • Posted 5 Dec 2024 01:44
  • Modified 5 Dec 2024 01:45 by poster
  • By DyslexicNerd_01
  • Wisconsin, United States
That worked perfectly!
It appears as though a user code is required upon startup now, but that's not a deal-breaker. Now I just need to teach these operators how to count and remember a user code!
Thanks for your time and for guiding me towards the solution I needed.
And now I'm made aware of the Info-Link system too.
  • Posted 5 Dec 2024 01:37
  • Modified 5 Dec 2024 01:39 by poster
  • By Br455Brute
  • Alberta, Canada
For the RR5700 and RMD6000 go into the service menu, Features, F11.1 = Enable. Then go to F11.3 and set the timeout. You shouldn't have to set any user codes in F11.2 to my knowledge, but if you wanted to you could so that users have to enter a code to start up the lift. You can have 25 user codes that are 4 digits long.
It's basically a simple version of Infolink built into the lift.
  • Posted 4 Dec 2024 23:53
I believe that info link shuts it down after ten minutes of inactivity. No sure of the cost per truck, but monitors a lot of activity including accidents.
  • Posted 4 Dec 2024 09:59
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
SMV (Konecranes) SL37-1200A
Ncn 110TH
Ncn 110TH 2015
