Mast Seals
Can anyone that has a parts/service manual get me the part number for the center main mast seals? Is there two sets? One for each stage? Went to leaking so I took it apart. Doesnt look bad but guess I will just change all the seals while it is apart! Searched online and can't seem to come up with anything definite. Thank You in advance!
  • Posted 29 Aug 2024 10:37
  • By Vaughn_Koehn
  • joined 29 Aug'24 - 1 message
  • Oklahoma, United States
Vaughn Koehn
Vaughn,
There are two kits listed for this model. Need to check and see if the cylinder has any numbers stamped into it. This will be the only way I can make sure kit is correct. Thanks.
  • Posted 10 Sep 2024 23:30
  • By Fishmech
  • Virginia, United States
Vaughn,
I will check for manual. You can also look at the cylinder to see if any numbers are stamped into the tube. Will follow up tomorrow. Thanks.
  • Posted 10 Sep 2024 05:46
  • By Fishmech
You are going to need mast number to get correct seals the number should be on back side of outside rail facing operator
Without it no one can help get correct seal kit
May take some searching but it is stamped on rail
  • Posted 30 Aug 2024 09:43
  • By John_Bradley
  • joined 10 Aug'22 - 268 messages
Jb69
SMV (Konecranes) 4632CC5
Terberg YT220
Terberg YT220
Michel Denis Michel Denis
