Blowing fuses Need HELP
So my Hyster 50xt keeps blowing the ign +1 fuse and I can't find out why. When the fuse blows all electrical power is gone but if you press the gas the engine is still running and will rev up. I changed the ignition switch and it also has a new starter. The problem didn't start until I replaced the starter. I have taken the new starter off and reinstalled it to make sure I installed it correctly and the problem is still happening. It is completely random when it does happen. So sometimes it will drive for a whole day and wont blow the fuse and the next day he starts it and it will blow the fuse.
  • Posted 13 Jun 2024 00:30
  • By Andrew_Fishback
  • joined 3 Apr'24 - 2 messages
  • Utah, United States
Andrew F.
Check wiring around starter for any sign of wear etc since it started after replacement of starter also look at where wiring for starter goes down from harness when you pulled on wires they may have gotten caught or rubbing engine
  • Posted 27 Jun 2024 07:29
  • By John_Bradley
  • joined 10 Aug'22 - 268 messages
Jb69
Andrew,
Since this only happens every so often, suspect you have a bad wire rubbing frame. First remove both front turn signal light if you have them. If fuse stops blowing, check light harness. If that doesn't work, unplug the strobe light and try again. Good Luck.
  • Posted 26 Jun 2024 02:03
  • By Fishmech
  • Virginia, United States
JLG G12-55A
SMV (Konecranes) 12-1200B
Lift Tek Elecar
JLG G12-55A
JLG G12-55A
