Komatsu k25 side shift
I work in industrial maintenance not a forklift mechanic so I need some help. One of our forktrucks keeps over extending the side shift to the left. I took the carriage off recentered the cylinder and grease the carriage. There is a v shaped aluminum channel that it slides on. I saw metal shavings and could tell it hasn't been greased so I figured a heavy bundle and side shift caused too much friction. Recentered put everything back now it's done it again a week later. I didn't see any stops to keep it from over shifting.
  • Posted 3 May 2024 05:31
  • By John_B
  • joined 3 May'24 - 2 messages
  • Virginia, United States
Thanks for the response. In the center there is still a circle with a 1/4 square still there. It's definitely metal on metal. I also see no plastic blocks. The carriage has been pretty well abused. The forklift operators tried to hammer the metal v channel back into place with everything thing still attached. I appreciate the help! I had to put a radiator in one the other day. I thought cars were bad to work on...
  • Posted 3 May 2024 22:24
  • By John_B
From what you said l believe this is a cascade sideshifter you will have to take it apart again under the metal channel in the center there should be a small about 1/4inch square block welded to the metal channel some times it brakes off it sits in the center of the carriage that what stops it from moving off center also you said that you greased the metal channel there should be two plastic wear strips that sit on top of the metal channel that is how the sideshifter slides it should never be on the metal also there should be two plastic wear blocks on the back of the carriage that is how it is built if there are not there they probably fell out when it went off center you will have to get them and put them back as it is possible the sideshifter could fall off and someone could get hurt. There should be a stamped serial number in the side of the sideshift carriage use that number to get parts hope l was of help.
  • Posted 3 May 2024 10:53
  • By Scott_
Scott
