e-24 code
code e24 replaced accel sensor cleared code and ran idle air volume learn unit is fine full rpm etc as soon as you put in gear code e 24 returns and puts truck into limp mode any help much appreciated
  • Posted 14 Mar 2024 03:24
  • By lonnster
  • joined 23 Feb'19 - 11 messages
did find a bad connection at vcm and trans sensor thanks cheers
  • Posted 23 Mar 2024 01:28
  • By lonnster
thanks seems to have been a bad ground at the vcm cheers
  • Posted 22 Mar 2024 23:25
  • By lonnster
Remove both kick panels in the foot steps. Check ground wires. There should be 2 attached to the mounting bolt for the VCM on the RH side. And a bunch attached to a bolt on the LH side. Repair if broken and clean mounting connection.
Check VCM and accelerator sensor connectors for corrosion and broken wires.
Check wiring from VCM to Accelerator.
  • Posted 17 Mar 2024 03:28
  • By BLey
  • joined 31 Jul'20 - 58 messages
I WOULD check signal to petal on signal 1 when in gear l believe you are loosing the signal wire when in gear ohm wire from petal to computer there is a short or open in wire also petal will put truck in limp mode.
  • Posted 15 Mar 2024 10:58
  • By Scott_
  • joined 16 May'21 - 313 messages
Scott
There are only a few things that will trigger limp mode in your machine. Low engine oil pressure, transmission temp, overheating engine and I believe MAF sensor. Make sure to check the connections on the trans temp sensor on the side of the transmission case. Either wire unhooked, broken, or just a bad connection. Or it might be a bad temp sensor also. Good Luck
  • Posted 15 Mar 2024 09:04
  • By mwjski
  • joined 26 Jan'18 - 33 messages
  • Montana, United States
JLG 260MRT
JLG 260MRT 2016
Flesherton, Ontario, Canada
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
