Error T241 T471 S278
Hallo Friends
I have a problem with my Linde R16 Active forklift, an error code appears on the display:
- T241
- T471
- S278
has anyone experienced this problem?
What steps should I take to deal with this problem?
thank you
  • Posted 20 Feb 2024 23:40
  • By pedro_apituley1
  • joined 30 Oct'15 - 14 messages
  • jakarta selatan, Indonesia
pedro.gpmforklift@gmail.com
Hallo Sir
I have found the problem, the problem occurs with the potentiometer on the steering wheel. I want to ask if I replace the potentiometer on the steering wheel, do I have to calibrate the new potentiometer?
Thank you
  • Posted 23 Feb 2024 11:49
Thank you for responding Michel, I will try to do these steps
  • Posted 21 Feb 2024 05:39
S 278
Fault description
Steering wheel potentiometer Error
Conditions of occurrence
Repeated errors detected between the two outputs from the Steering Wheel potentiometer
Result
Steering shuts down, Steering OK signal off.
Possible cause
Check Steering Wheel potentiometer (See Service Information 410/07)
Wiring fault (See Service Information 411/09)
  • Posted 21 Feb 2024 01:43
  • By michel_v
  • noord holland, Netherlands
GemOne
Taylor TT300
USD98,500
Kalmar-Ac P100CXD
