Activating travel alarm
Hello
I recently replaced the1310 Curtis vechicle controller and I don't see the alarm in the spyglass setup !any ideas would be appreciated!
  • Posted 12 Feb 2024 03:33
  • By Pistolpeted
  • joined 15 Dec'18 - 34 messages
  • Connecticut, United States
Ok thanks for the info
  • Posted 21 Feb 2024 22:48
  • By Pistolpeted
Pistol,
When replacing the 1310 controller with new, you must submit the internal serial number of the new controller to the engineer so they can send you a passcode that sets up the controller with the options sold with the lift. Unfortunately, there is nothing I can tell you to do to turn on the options. Will need to get dealer involved. Thanks.
  • Posted 20 Feb 2024 23:32
  • By Fishmech
  • Virginia, United States
Thanks for the reply
Yes I'm aware of the numbers to activate each alarm,Jo just don't see that parameter were it usually is in the setup!
  • Posted 20 Feb 2024 22:50
  • By Pistolpeted
Pistol,
The alarm setting is under the setup menu, motion alarm. Each number is for different alarms, ie alarm goes off in forward and reverse, or can bet set for only reverse or also include when mast is raising. Good Luck
0 = No Alarm
1 = Backup (BU)
2 = Forward (FWD)
3 = BU & FWD
4 = Lift
5 = BU & Lift
6 = FWD & Lift
7 = BU, FWD, & Lift
8 = Lower
9 = BU & Lower
10 = FWD & Lower
11 = BU, FWD, & Lower
12 = Lift & Lower
13 = BU, Lift, & Lower
14 = FWD, Lift, & Lower
15 = BU, FWD, Lift, & Lower
  • Posted 20 Feb 2024 03:27
  • By Fishmech
Combilift Ltd
Nagano NUL120-6
Terberg RT223
