TRANSMISSION PROBLEMS
Hello have a hyster H 3.50 XL SRN F5A716 OJ S/O 358060
WITH gm 4.3 6cyl lpg engine
it has mechanical powershift 1 speed
problem only goes backwards no forward
  • Posted 10 Jan 2024 20:02
  • By IVO_SERTIC
  • joined 10 Jan'24 - 2 messages
  • Belgium
IVO,
Sorry, skipped over that. Need to check all springs in the valve. I will try and get a breakdown and have a closer look. Thanks
  • Posted 15 Jan 2024 09:11
  • By garland_m
  • joined 16 Oct'09 - 213 messages
  • Virginia, United States
Work Hard and Fish Long
it has a mechanical powershift no electrical solenoids
  • Posted 15 Jan 2024 05:47
  • By IVO_SERTIC
  • Belgium
IVO,
Need to verify trans solenoids are operating correctly. Also, make sure the alternator is operating correctly. Low voltage is creating loss of functions on lift. If you can switch wires from forward to reverse solenoid, this would verify wire or possible failed solenoid. If it just happened, suspect wires, solenoid or switch in steer column. Doubt forward clutch just failed. Good Luck
  • Posted 14 Jan 2024 08:26
  • By garland_m
UN Forklift FGL18T
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
