Left Pedal Message
Brake pedal switch has been replaced and has been calibrated so switch opens and closes between 18% and 35%. Software has been updated. Features has been set up. Calibrated tilt sensor and Brake pedal several times during troubleshooting. Have battery voltage at brake pedal input on access 3 when pedal is pressed. Battery has been replaced with known good battery. Replaced floorboard with running truck and calibrated brake pedal again.
Any ideas on Left Pedal Message?
  • Posted 25 Nov 2023 05:16
  • By BigAl88246
  • joined 5 Apr'17 - 11 messages
If you start with the brake petal depressed, you may have to do the crown shuffle (pick up your feet like your walking) a few times. The truck wants to see the switch in an opened and closed state before it will allow for drive functions.
If you go into the service menu the analyzer should show you if that switch is opened or closed. Make sure it switches between opened and closed when you pick you foot up. I think it is A2.1.2
0 = switch open
1 = switch closed
  • Posted 27 Nov 2023 09:52
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 226 messages
  • Wisconsin, United States
