drive unit oil change
Hi Guys,
Today I changed the oil on my trusty old 30WRTL's drive unit and found a problem.
When refilling, oil came from the bottom of this slot, not the level plug at the right. There was residual silicone over the slot so I believe something is missing here and someone has previously tried to seal it. There is a 3/8"UNC thread inside the round slotted part that probably retains a sealing cover?
Pic here:
https://i.ibb.co/wSmYf8j/20231116-141102.jpg
Does anyone have a pic or parts diagram to show what is missing? I can make a part to fix this if I know what is supposed to be there.
Many thanks for any assistance.
Ben.
  • Posted 16 Nov 2023 15:28
  • Modified 16 Nov 2023 15:28 by poster
  • By ben_p
  • joined 14 Jun'16 - 3 messages
  • Queensland, Australia
Thanks for your reply.
I have no desire to pull it apart.
If there's no parts missing here, I'll just find a way to seal it up externally.
Thanks again.
  • Posted 17 Nov 2023 08:31
  • By ben_p
i don't have any parts literature on this model but from what i remember on these drive MDU's is that component your pointing at in the picture is a pin that supports an idler gear inside the drive unit. It presses into the case into some bearings and is shimmed too i think so it sets a preload on the gear/bearing it corresponds with. As far as the leak? I'd say that it was not properly sealed when assembled and if there is oil coming from the center 'threaded' hole then there is an issue with the pin. That center hole is only there to provide a way to insert a tool so it can be removed using a snatching tool. if i remember there might be an oring sealing the outside of that pin and it could be bad allowing oil to come out. I would clean it up with some brakecleaner and run it and make sure where the oil actually is coming from. Of course if it actually is coming from the center hole then the pin might be damaged and would have to be replaced to stop the oil leak.
Just FYI, if you try and remove that pin without removing the top of the mdu then the gear on the inside will fall down and you will have a hard time getting it back in place and would ultimately have to take the unit apart anyway. If you've never done this before i would get some assistance from someone that has.
  • Posted 17 Nov 2023 01:20
  • Modified 17 Nov 2023 01:23 by poster
