cranking / starting issue
I have a 5FGC20 Toyota fork lift that has a cranking/ starting issue.
I replaced the starting battery with a new AC Delco 685CCA Battery.
When I turn the key to the ON position the 2 red rectangular lights light up on the dash panel.
The lights stay on and when I turn the key to the CRANK position to crank the engine nothing happens.
When I connect a booster / starter charger to the battery and turn the key to the ON position the lights come on then turn off and when I cycle the key to the CRANK position the engine starts and stays running with or without the battery charger connected until I cycle the key to the OFF position.
To restart I have to follow the same process as above.
Any idea as to what the problem maybe ?
Thanks Pete S
  • Posted 7 Jun 2023 05:46
  • By Pete_Spencer
  • joined 7 Jun'23 - 1 message
  • Wisconsin, United States
P Spencer
Toyota 8FG25
SMV (Konecranes) 4538CCX4
