drive motor sensor readings
What is the correct reading of the sensors when traveling and when stopped?
  • Posted 9 May 2023 07:39
  • By bluevan
  • joined 17 Aug'22 - 6 messages
blue van
That lift has an onboard analyzer. Service manuals are available through Toyota parts dept's. A simple password input gets you to the I/O Monitor 2, where you can monitor the speed sensors. The correct readings are in the manual. I assume you have error codes relating to the sensors? And I also assume you have checked all the harness connections.
  • Posted 12 May 2023 00:26
  • By ErichO
  • joined 26 Oct'21 - 83 messages
  • Washington, United States
Yale Lift Truck Technologies
