ERROR 524223-0
Hello. Our clamptruck unit reverse functions only for 1 meter then engine goes neutral with error code 524223-0. Forward and other functions are ok. What do you think is the problem? I already checked 2 sensors at the top of the transmission and replaced the one near the reverse solenoid but still not ok.
Hope you could help
  • Posted 1 Feb 2023 20:30
  • By Jayson
  • joined 21 Feb'22 - 12 messages
  • Philippines
Replaced transducers, problem solved. Thank you!
  • Posted 2 Feb 2023 19:48
  • By Jayson
  • Philippines
Code is reverse trans pressure sensor to high replace the sensors for forward and reverse or try swapping them and see if it goes to the forward
You could also have a bad wire.
  • Posted 2 Feb 2023 15:56
  • By Scott_
Scott
