Handset Does Not Power Up ERC040
I have been through a lot of troubleshooting. I now have a LX Handset with the EV100/200 cable. I cannot get the handset to power up. Tried key off and key on holding down the CONT, but nothing. I tested the voltage on the pins of the Y connector but I cannot find any reference online on what voltage the test pins should have. 7 pins have no power. The others range from 0.23v to 0.905v. Does anyone have a diagram or list of what power should be on the test pins on the Forklift? I am assuming none of the power readings I am getting are enough to power the handset. Thank you for your help.
  • Posted 29 Dec 2022 16:19
  • Modified 30 Dec 2022 02:13 by poster
  • By BRAD_ISHAM
  • joined 28 Dec'22 - 12 messages
  • Kansas, United States
Showing items 1 - 16 of 16 results.
I installed a used (and guaranteed) control unit I purchased on eBay. The handset connected right away. Had to reprogram the card to my units specs. Everything works now. Thanks for your help. The card was the problem.
  • Posted 27 Jan 2023 02:50
  • By BRAD_ISHAM
I've had good luck with cards and panels from FS. I can't remember the accelerator setup on that model but usually you can repair them yourself with the proper speed pot and switches.
  • Posted 10 Jan 2023 07:33
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
That's good to know. I checked with Flight Systems for an accelerator circuit. They said they don't have any exchange units in stock. They never did tell me how long it would take to rebuild mine. Any experience with them on rebuilds?
  • Posted 10 Jan 2023 03:03
  • By BRAD_ISHAM
There is a z-plug kit for replacing wallowed out plugs. (The connection at the z-plug has been a problem since the first EV-100s) They sell for about $50 each but I just had one on back order for two months before giving up on it. Flight Systems sells them. But I don't think anyone has them in stock right now.
Part # YT582072108
  • Posted 10 Jan 2023 01:48
  • Modified 10 Jan 2023 02:23 by poster
  • By lumberjack
Scott, Your first post was correct about the card. I purchased a used card (actually the complete control unit) and that fixed the issue with the handset. The handset comes on now with the replaced unit. Now I need to program the card. It is the same model number but I am certain the settings will not be correct for my forklift. I am having trouble finding the programming settings for my forklift erc040acn36. Does anyone know where I can access the settings for a specific model? Thanks, Brad
  • Posted 9 Jan 2023 10:18
  • Modified 9 Jan 2023 10:19 by poster
  • By BRAD_ISHAM
FYI: Found one on Amazon Hyster P/N 1308651 if anyone in the future needs one. Does anyone know where I can purchase a couple of the 14-pin connectors (Z and Y) so I can make a bench setup to do testing on?
  • Posted 6 Jan 2023 05:00
  • Modified 6 Jan 2023 08:18 by poster
  • By BRAD_ISHAM
Ok, well one other thing could be the cable. I've had those go bad. Maybe you could try it on another EV100. Then you'd know if it was your tool or the truck that's broken.
  • Posted 5 Jan 2023 10:10
  • By lumberjack
I don't think so. It just have "ON" and "OFF" with the key switch.
  • Posted 5 Jan 2023 09:21
  • By BRAD_ISHAM
Does the forklift have a line contactor that you close by turning the ignition switch to the "start" position? Some Hysters have this system and they're pretty much the same truck these days.
If you do have a line contactor you can use the handset by hot-wiring the line contactor closed then plugging in the handset as normal. (starting with the key switch off)
  • Posted 5 Jan 2023 08:01
  • By lumberjack
The PY plug on my card just has a cover. Not sure where the gauge is wired in on my unit. It looks like a non-smart gauge. Only shows battery charge level and hour meter. Don't think it has any other functions.
  • Posted 4 Jan 2023 10:25
  • By BRAD_ISHAM
Brad l looked at what you said the gauge should not work when the handset is plugged into the py port that is usually where the power comes out of the ev100.to the gauges.
  • Posted 1 Jan 2023 05:01
  • By Scott_
Scott
I will check to see if the gauge works when the handset is plugged in. I know it works without the handset, just haven't looked with the handset plugged in. The gauge only has battery charge level and hours.
I'll ohm the wires from the connector to the dash to check for any breaks.
I will check the wires on the handset and see if I can power it up with 24v.
  • Posted 31 Dec 2022 09:16
  • By BRAD_ISHAM
Brad does the bdi gauge work when the handset is not plugged in if so I would think the handset is bad but there is a way to test the handset and card on a bench you need a 24volt battery 2 car batterys in series will work you need to hook a wire to Pz plug number2 and to the battery negative terminal than you need to hook 1 wire to number 7 on Pz plug than to battery positive than hook handset to py plug hand set should power on.
I believe the py plug goes to the instrument panel l believe they only use 5wires you could ohm the wires from the connector to the dash see if there is any breaks if not it is possible that you have a bad card. l believe py1 is white to panel py2 isblack to panel py3 is green to panel py 4 bare to panel py5 red to panel l don't think that py6 and 7 are used some of the wirs are for pump to traction card. To check you have to take card out of truck. It would be better if you had a cheater pz plug to do it with. Hope l was of help
  • Posted 31 Dec 2022 05:37
  • By Scott_
Scott
I removed the seat switch jumper. Battery has 39.8v and TB4 has 39.5v. Handset still will not power up.
Is there a way to check the pins on the PY test connection to see if it is providing power to the handset?
  • Posted 31 Dec 2022 02:29
  • Modified 31 Dec 2022 02:41 by poster
  • By BRAD_ISHAM
The seat switch is jumped. I know this because we jumped it for troubleshooting before I got the handset. I will go to the shop tomorrow and pull the seat jumper. Also will check the TB4 and get back with you. Only has the battery/hour meter. Thank you.
  • Posted 30 Dec 2022 10:30
  • Modified 30 Dec 2022 10:30 by poster
  • By BRAD_ISHAM
Does the display in the lift truck work when the hand set is not installed and does it have a battery indicator function installed if not and the seat switch is jumped or some one is in the seat the display will be blank. Look at that first.also make sure you have power to the ev100 card at TB4 should be battery voltage.get back to me l will try to help if this does not work.
  • Posted 30 Dec 2022 04:48
  • By Scott_
Scott
Terberg YT222
Terberg RT403
Terberg YT222
Terberg RT403
