Hard slam Going Into Drive, F/R
Unit slams hard when putting into forward or reverse, changed out the #1 rectivier but no difference. No contactors welded together...then drive cuts out.
  • Posted 10 Nov 2022 06:35
  • By JAKE2
  • joined 7 Jul'17 - 36 messages
Ev100 controller?? Change rec5 but you really need to plug an handset into it
  • Posted 12 Nov 2022 07:41
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Do you have a hand set if so hook it up and check if any codes in the GE controller.
  • Posted 11 Nov 2022 12:47
  • By Scott_
Scott
