Error -42
I have a Clark ECG 30 and it completely stopped on an employee in the middle of the aisle. It will lift and everything but it will not go forward or reverse. When you press on the pedal, it shows a code of -42. I had a new accelerator switch so i switched it out and it didn't help. I don't have a manual for this machine and not finding alot of information on this truck online yet.
  • Posted 24 Aug 2022 06:18
  • By tg0486
  • joined 29 Jul'17 - 78 messages
  • Missouri, United States
Thank you for the help. I didn't see the exact wire you was talking about for sure but I did go through and loosen then retighten all connections i could see and the lift started moving. Hopefully that was all it was.
  • Posted 24 Aug 2022 20:13
  • By tg0486
42 Controller "motor current sensor" input is
missing(PZ12-Green).
This status code will be displayed when the voltage
between PZ12 & PZ13 greater than 0.1 volts with no
current flowing in the motor circuit.
MEMORY
RECALL
NO
CORRECTIVE ACTIONS TROUBLE-SHOOTING DIAGRAM
Circuits valid
for Traction
Controller
SYMPTOM
No power to traction motor in control range.
POSSIBLE CAUSE
Open sensor wire circuit to PZ12.
* Check for loose connection or broken
wire(green wire)from current sensor to
PZ12 on the logic card
  • Posted 24 Aug 2022 07:19
  • By andrew_k
  • joined 17 Mar'07 - 337 messages
  • England, United Kingdom
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SMV (Konecranes) 4538CCX4
edition #1257 - 20 November 2025
USD1
