R14-01 ERROR CODE T591 T335
I am having a problem with the reach truck sometimes working and sometimes not working for a few days and the error code T591 & T335 display on the secreen.
Please advise what are these error codes refer to?
Thank you in advance and Merry Christmas to you all.
  • Posted 21 Dec 2021 19:20
  • By Isa_Alderazi
  • joined 25 Feb'21 - 10 messages
  • Bahrain
Isa Alderazi
591 Battery voltage for BDI is too low (voltag-difference > 4 V).
T 591
Fault description
Conditions of occurrence
Result
Dummy Flag: intervention to be defined
Possible cause
  • Posted 23 Dec 2021 00:11
  • Modified 23 Dec 2021 02:13 by poster
  • By michel_v
  • noord holland, Netherlands
335 Contact from main contactor 1K1 to lifting module A2 remains open even though coil 1K1 is energised (voltage difference X13:A30 - X13:A15 > 15 V; voltage difference X13:K1 - X13:A14 > 4 V).
T 335
Fault description
X13:A30 minus X13:A15 greater than 15.0[V]. X13:K1 minus X13:A14 greater than 4.0[V]
Result
disable all traction unit
Possible cause
Steps to eliminate the fault
Check X13:A14
  • Posted 23 Dec 2021 00:10
  • By michel_v
LINDE R14-01
P21120G01547
2016
48V
6.5 KW
  • Posted 22 Dec 2021 18:44
  • By Isa_Alderazi
  • Bahrain
Isa Alderazi
serial nr??
  • Posted 22 Dec 2021 18:39
  • Modified 22 Dec 2021 18:39 by poster
  • By michel_v
Airman ENCL045
Terberg YT222
