Tilt only
I have a Crown 35 RRTT That operates the tilt in both reach & tilt modes, transverse through the buttons & light indicates on dash correctly, have 36 volts at valve, also changed the valve with a working valve complete, still have fault, any ideas or suggestions please!
  • Posted 22 Nov 2021 13:56
  • By Onsite
  • joined 5 Sep'18 - 16 messages
  • New South Wales, Australia
Lifting Services to new Heights
You can't put your email address in your post. It gets deleted to prevent spam bots. If you want to list your email address you have to put it in your signature block so it shows up underneath your location. Please use your email and email me at my address. You can find it below underneath my favorite quote.
I'm in the USA
  • Posted 24 Nov 2021 14:09
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
Are you in Sydney West?
  • Posted 24 Nov 2021 08:59
  • By Onsite
My email address is info at onsiteforkliftservices dotcom dotau
Any help much appreciated
  • Posted 24 Nov 2021 08:58
  • Modified 25 Nov 2021 00:19 by administrator
  • By Onsite
Send me your email address. Mine is in the signature block below.
Does your truck also have sideshift?
  • Posted 24 Nov 2021 06:06
  • By 1CrownTech
Where is the tilt valve you are suggesting?
  • Posted 23 Nov 2021 19:49
  • By Onsite
The tilt/ sideshift solonoid valves are on carriage. What happens if you disconnect the wires to the coils and you try and operate? Does it still tilt?
  • Posted 23 Nov 2021 17:22
  • By 1CrownTech
Serial W18280, yes the valve operates both I take it, valve behind plate on mast.
  • Posted 23 Nov 2021 14:25
  • By Onsite
There are several. Did you replace the tilt solenoid valve? Hyd fluid travels path of least resistance. If the tilt solenoid valve was stuck open or getting power when not supposed to then it will open.
What is the serial number of the truck?
  • Posted 23 Nov 2021 11:58
  • Modified 23 Nov 2021 12:01 by poster
  • By 1CrownTech
The hydraulic value on front of mast.
  • Posted 23 Nov 2021 09:06
  • Modified 23 Nov 2021 09:07 by poster
  • By Onsite
Which valve did you replace?
  • Posted 23 Nov 2021 02:12
  • By 1CrownTech
Sue Tomic Sue Tomic
Lift Tek Elecar
Lift Tek Elecar
