My Z60/34 Slow Platform Control
Hi,
My genie works fine from the ground but when I use the platform controls it is way slow. Any advice on what settings, or wires to check? Thanks Matt
  • Posted 16 Nov 2021 02:23
  • By matt_miller
  • joined 16 Nov'21 - 3 messages
ok matt, to clarify how the platform works versus how the ground controls work...
-ground controls are a fixed speed controlled by some diode blocks in the ground control box, they do not vary any and stay at the same fixed speed with the boom down or up, doesn't matter (the drive system does not apply from the ground box of course).
-the platform controls vary depending on what function it is, the boom and drive controls use joystick operation and are variable speed controlled. Any function that is a toggle switch control is the same as the ground control and should operate basically the same as the ground does in fixed speeds, but the platform fixed speeds are different because of the LS switches and boom positioning. Also there is a button/toggle that controls the 2 speed drive control that will vary speeds also, there is a pict-o-gram showing an encline v/s flat surface, encline mode is naturally slower for more torque for climbing ramps and hills, the flat out mode is for level ground running and is considerably faster by engaging the 2 speed circuit in the drive motors. Now as far as the difference in speeds at the platform it also depends on the LS switch positions are in when the boom is stowed or elevated but like from the ground, the speed is a fixed speed, non-variable and will change as the LS switches change when raising the boom(i mentioned this above i think).
The boom LS switches, they only change the drive speeds and slow the machine down when the boom is elevated past a certain point. turntable speed is also affected when elevated. I think it does also change the fixed speeds when elevated too so the boom will not jerk around so bad when it is in higher elevated positions.
As for how they are wired? it varies depending on their function and the position of the boom. The wiring schematic shows all switches as if the boom is 'stowed' (fully lowered). LS1 NC, LS2 NO, LS3 NO, LS4 NC.
If your still not sure when you remove the switch cover you can see it clearly marked on the actual switch inside the body and determine how to wire it in from that.
If you want the service book it is freely available to the public on genie's website and the pdf number for your machine i believe will be 52856. The electrical schematic is on page 174 in the pdf and the section in the schematic where those limit switches are shown is in the J 6 area. (if your not sure on navigating schematics and diagrams look at the top edge and left edge of the schematic and you'll see letters across the top and numbers on the left, in a straight line from the letter and number make them both meet inside the diagram and that is the area the switches are located in the diagram).
  • Posted 20 Nov 2021 10:43
Thanks. To be clear, it is not slow from ground control so the limit switches only affect the platform control? Also are the switches NO or NC when the boom(s) are not extended etc. Thanks for all your help!
  • Posted 20 Nov 2021 04:43
  • By matt_miller
no this will be fine here. One of the first things i would check is the boom position, is it fully lowered and the extension fully retracted? are the limit switches on the boom intact, the wiring for those switches ok?
If the boom is elevated past a certain point it will slow everything down even the extension can cause a slow down if it is extended out more than a few inches. You'll want to check those switches and make sure they are working, not damaged. There are 4 limit switches you need to check that are located at different positions on the boom. LS4 (secondary boom limit switch) is located out on the secondary boom up near the basket area ON the boom arm, The lift interlock limit switch LS2 is located under the primary boom further back towards the tractor unit section on the boom, the primary boom drive limit switch LS1 is located at the rear joint of the primary boom arm, and the primary boom extend limit switch LS3 is located in the end of the primary boom.
The only reason i can think of that slows the functions AND the drive unit too is if the machine thinks the boom is elevated, that is the only time ALL operations are slowed down.
Check those switches and see if you can find any issues with them before you do anything else.
  • Posted 19 Nov 2021 11:04
Thanks. I could not find a z60/34 so do i start one?
My Serial number is z6006-1513, it is a 4wd diesel
ALL functions are turtle slow even when I switch to fast mode etc.. Including driving...
  • Posted 19 Nov 2021 01:13
  • By matt_miller
need clarification on the model (and serial number) before anyone can give you any advise. You posted this under the Z45/25 section but your subject line says Z60/34. And which functions are slow? be specific please. Details matter :o).
  • Posted 18 Nov 2021 23:05
Aichi RX07B
Toyota 02-2TD20
Sue Tomic Sue Tomic
