Code 64 - Very slow lifting
We just brought in a used machine and it is very slow to lift. It will code 64 if you hold it. Any thoughts from Raymond experienced folks?
  • Posted 29 Oct 2021 03:45
  • By Dan_Selph
  • joined 29 Oct'21 - 5 messages
If any one sees this and doesn't see their solution, try this: Check your battery voltage, check the lift pump splines, and if equipped with a mini-mast check your proportional valve isn't sticking. Hope this helps!
  • Posted 6 Oct 2023 11:06
  • By snack_fury
  • joined 6 Oct'23 - 1 message
  • Tennessee, United States
chequea los switches del mastil, mira si tiene un leveler malo. si eso esta normal, cambia la tarjeta controladora CCC
  • Posted 10 Feb 2023 02:30
  • By max_h
  • joined 28 Sep'17 - 13 messages
HOLA
YO TENGO EL MISMO PROBLEMA.
¿COMO LO SOLUCIONO AMIGO?
Littoral Translation
HELLO
I HAVE THE SAME PROBLEM.
HOW DO I FIX IT FRIEND?
  • Posted 29 Jul 2022 01:51
  • Modified 29 Jul 2022 15:00 by administrator
  • By almacenes
  • joined 29 Jul'22 - 3 messages
  • El Salvador
titoooliva
Esie Cortez Esie Cortez
Aichi SR10C1SM
Crown RD572513TT6860R
Noblelift
Oxford Ct, United States
