Linde H80D D156 error
Hey guys I have a Linde H80D-01 serial number H2X396B00348 it was not used for around a year and tried to start it but it only starts sometimes and when it does start it will not drive or lift/crowd back where should I be looking first other than the obvious such as fuses and wiring damage ect?
Thanks Jake
  • Posted 17 Oct 2021 18:44
  • By jakep
  • joined 17 Oct'21 - 3 messages
  • Victoria, Australia
take a good look at the bottom of the fuse box for broken cable
check wiring harness of fuse box running over motor
  • Posted 14 Nov 2021 20:06
  • By michel_v
  • noord holland, Netherlands
Thanks mate I'll do some further inspections and if I have no luck I'll give you a buzz thanks heaps
  • Posted 23 Oct 2021 22:30
  • By jakep
+642108867127
  • Posted 23 Oct 2021 15:40
  • By Lindetechnz
  • joined 28 Apr'21 - 58 messages
  • New Zealand
Lindetechnz
Thanks for that I will go over it all throughly I have visually looked at it but not pulled all the tape off the wiring yet, do you have an email address/ contact number I can contact you on if I don't find any wiring damage as the Linde dealer in my area is useless, I'm in Australia
Thanks Jake
  • Posted 23 Oct 2021 15:18
  • By jakep
Hi
I think D156 is a heart beat message error
In other words a can bus fault
That Probally the reason you have No drive or lift
Check the canbus wiring from the display to the controller in the rear panel
Will be a twisted pair so easy to see in the loom
  • Posted 21 Oct 2021 18:53
  • By Lindetechnz
  • New Zealand
Lindetechnz
Briefs United States
GemOne
