WARNING LIGHT
I HAVE A CAT V50DSA 2NC01101 THAT HAS A LIGHT ON IN CORNER OF DASH. IT HAS A CRANKCASE LOOKING SYMBOL WITH A SPLASH INSIDE IT AND A LINE UNDER IT WITH A TRIANGLE. LOOKS LIKE LOW OIL LEVEL BUT CAN NOT FIND SENSOR
  • Posted 1 Oct 2021 05:16
  • By TKOforklift
  • joined 24 Nov'07 - 30 messages
  • British Columbia, Canada
TKO Forklift and Equipment Repairs
Kamloops BC
250-819-6575
tkoforkliftservice@gmail.com
if there is an oil level sensor on it that would be located on either side of the oil pan near where it meets the engine block. This might also be a coolant sensor level warning light which in that case there would be a sensor on the side of the radiator or possibly in the reservoir.
i looked through my material i have on that truck but it does not show the dash light indicators , i believe that would be shown in the operators manual which i do not have. But there are only to fluid levels it would be indicating if it has an engine block pictogram in it, that would be oil level or coolant.
  • Posted 4 Oct 2021 02:09
