No hydraulic functions
This has little to no hydraulic functions, including steering. Filters were changed a week ago. We had a problem with the lift lower switch a week ago also. I don't think the filters failed that quickly. Can it be in the controller?
  • Posted 20 Aug 2021 03:47
  • By forkmen123
  • joined 5 Jun'12 - 50 messages
Kevin
Steering has priority over all other hydraulic functions. As long as the engine is running you will have steering pressure waiting to be used.
  • Posted 23 Aug 2021 11:33
  • By stam
The only thing that makes me
hesitate, is that valve is controlled by the hydraulic ECU. Are you saying the steering is always working and does not open electronically?
  • Posted 23 Aug 2021 10:59
  • By forkmen123
Kevin
I have thought of that. I will take a pressure reading tomorrow.
  • Posted 23 Aug 2021 10:44
  • By forkmen123
Kevin
Sounds like your pump is not functioning.
It should always have power steering as long as the engine is running.
  • Posted 23 Aug 2021 09:59
  • By stam
What are the voltage readings for the solenoids on the control valve. I read 7volts. Anyone know where the power comes in to the hydraulic controller?
  • Posted 22 Aug 2021 07:02
  • By forkmen123
Kevin
Terberg YT220
Manitou M50-4
