Shows 0% BDI on fully charged battery
Hi guys;
I'm having an issue with a PC4500 80 that shows 0%bdi on a fully charged battery. I have checked the normal stuff that goes wrong with these when that happens, ie FU1 on Access 3 , the small 4A and 15A fuses are good too. The truck automatically codes out when the brake button gets pressed. Active codes are as follows: 537 535 323 and 562. Any help on this would be appreciated.
  • Posted 15 Jul 2021 10:52
  • By Grumpy_Mechanic
  • joined 15 Jul'21 - 1 message
I know this is an old post, but I'm having the same issue. Any luck?
  • Posted 15 Aug 2023 23:03
  • By Marvin_Mason
  • joined 19 Jul'22 - 1 message
  • Maryland, United States
Your solenoid switch on pump motor is welded
  • Posted 10 Aug 2022 07:57
  • By Ratm
  • joined 21 Jun'19 - 17 messages
Stoney
What is the battery voltage? Check static voltage, and then see what it drops to when you close the brake switch
  • Posted 16 Jul 2021 02:33
  • By Triggs
Sue Tomic Sue Tomic
UN Forklift FGL35T
SMV (Konecranes) 4632CC5
Sue Tomic Sue Tomic
